Enable an existing ERPS ring/sub-ring.
| ring-name | Alphanumeric string that identifies the ERPS ring. |
N/A.
Use this command to enable an existing ERPS ring/sub-ring.
The following example enables an existing ERPS ring identified as “ring1”:
enable erps ring1
This command was first available in ExtremeXOS 15.1.
This command is available on all platforms supported in 12.6 and forward that are running ExtremeXOS.
